Автор Тема: AVR Studio4 и оптимизация  (Прочитано 46494 раз)
« : 23/07/2014 19:05:20 »
Народ, помогите разобраться, накалякал снифер для определения УОЗ квадроцикла
//#include <mega8.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdlib.h>
volatile unsigned char i = 0; data_e; temp = 0;
unsigned long buffer;
volatile unsigned int counter_rpm; count; rpm; rpm1;
unsigned int addr; angle; angle_val[150];
ISR(INT0_vect)
  TCCR1B=0x02;
ISR(INT1_vect)
 TCCR1B=0x00;
 //if (temp == 0) count = 0;
 count=TCNT1;
 TCNT1=0;
 i=1;
ISR(TIMER1_OVF_vect)
  counter_rpm++;
ISR(ANA_COMP_vect)
  rpm = TCNT1;
  rpm1 = counter_rpm;
void EEPROM_write(unsigned int uiAddress, unsigned char ucData)
/* Wait for completion of previous write */
while(EECR & (1<<EEWE))
/* Set up address and data registers */
EEAR = uiAddress;
//temp = ucData>>8;                              // сдвиг вправо на 8 бит
EEDR = ucData;
/* Write logical one to EEMWE */
EECR |= (1<<EEMWE);
/* Start eeprom write by setting EEWE */
EECR |= (1<<EEWE);
int main(void)
 cli();
 TCCR1A=0x00;
 TCCR1B=0x00;
 MCUCR |= _BV(ISC11) | _BV(ISC01);
 MCUCR &= ~(_BV(ISC10)) & ~(_BV(ISC00));
 GICR |= _BV(INT0) | _BV(INT1);
 DDRD &= ~(_BV(PD6)) & ~(_BV(PD7)) & ~(_BV(PD2)) & ~(_BV(PD3));
 PORTD = 0xff;
 ACSR |= _BV(ACIE) | _BV(ACIS1) | _BV(ACBG);
 ACSR &= ~(_BV(ACD)) & ~(_BV(ACIC)) & ~(_BV(ACIS0));
 SFIOR &= ~(_BV(ACME));
 data_e = 0xff;
 for (addr=0; addr<512; addr++)
  EEPROM_write(addr,data_e);
 counter_rpm=0;
 sei();
 while(1)
   temp = 0;
   if (i != 0)                         - это условие проверяется только после вычисления следующей строки, и цикл while передает управление на строку addr = 141176/buffer
    buffer = ((unsigned long)counter_rpm * 65536 + (unsigned long)count);
    addr = 141176/buffer;                                    // через 50 RPM по два байта на угол
    angle = ((buffer - ((unsigned long)rpm1*65536 + (unsigned long)rpm))*423)/buffer;    // угол * 10 !!!
//    data_e = angle/256;
    angle_val[addr] = angle;
//    EEPROM_write(addr,data_e);
//    data_e = angle;
//    addr++;
    counter_rpm=0;
    i=0;
   buffer=0;                                    - если убрать эту строку, то цикл while вообще делает только один проход, и стопорится в самом конце программы ( rjmp $ )
Дык эта падла, при оптимизации в цикле while(1) {} неправильно переход и проверку условия переменной i делает.
Без оптимизации все компилирует правильно, но время обработки прерывания становится неприлично большим.
Прям хоть на АСМ-е пиши!
Re: AVR Studio4 и оптимизация
« Ответ #1 : 23/07/2014 20:19:40 »
что значит не правильно i проверяет ? ну ты ваще замудтил... нагрузил 8 битную бедолагу 32-у битными типами (зы,у кого подпись про невпихуемое ?).. кста, я бы *65536 заменил бы на <16. арму юзай.
« Ответ #2 : 23/07/2014 21:23:16 »
переменную i проверяет не в том месте цикла где надо, а на строку ниже.
« Ответ #3 : 23/07/2014 21:31:58 »
А где i инициализируется?
Модификатор volatile говорит компилеру не делать никаких предположений относительно значения i. В дебаг-режиме все переменные обычно обнуляются, если не указано иное, как только включается оптимизация volatile unsigned char i = 0; из-за volatile присвоение i=0; не выполняется. Нужно инициализировать volatile переменные (в том числе и temp) в начале main()
Так что, стоит сначала i и temp явно сразу после cli проинициализировать - должно помочь. Вообще-то попробуй использовать модификатор const вместо volatile, (правда придётся при изменении этой переменной помучатся с преобразованием типа) - согласно стандарту С глобальные переменные(и выражения с их использованием) с модификатором const не оптимизируются -> не должно быть оптимизации перехода if(i != 0)...
СТОП!!! Я ошибся, надо использовать static, а при изменении переменной использовать преобразование типа к обычному int.Хотя по ANSI C оптимизации не подлежат и глобальные переменные - стоит всё-таки поиграться с отсутствием volatile
volatile конкретно по PICам и прочим встройкам - по идее компилер не должен оптимизировать if(!=0)
« Последнее редактирование: 23/07/2014 22:11:56 от drfaust »
« Ответ #4 : 24/07/2014 12:23:01 »
... volatile unsigned char i = 0; из-за volatile присвоение i=0; не выполняется....
интересный оборот... а где об этом говорится ?
« Ответ #5 : 24/07/2014 13:42:56 »
Да вроде нигде. И возможно не из-за volftile. Только в дебаге - вся память проги дебаггером заливается 0-ми. А в релизе, да ещё и с оптимизацией это не всегда так. Локальные переменные инициализируются, а вот глобальные, насколько я помню - зависит от компилятора.
Мог и напутать чего... Во всяком случае - стоит попробовать проинициализировать до  установки обработчиков.
К стати, сначала ставим обработчики (по программе), а потом зачищаем епром (процесс долгий - сколько раз обработчики сработают? и есессно установят i в 1). Может стоит сначала епром проинициализировать, а уже потом обработчики прерываний установить?
« Ответ #6 : 24/07/2014 14:02:35 »
Eeprom инициализируется в майне при запрещенных прерываниях, попробовал переменную buffer сделать локальной - бесполезно, та же байда. Ща попозжа попробую ее проинициализировать. Касби 02к приперли.
« Ответ #7 : 24/07/2014 14:56:44 »
От япона мать!, победил я его!!! В перечислении переменных вместо точки с запятой надо было запятую ставить.
Переменные buffer, angle, addr сделал локальными до кучи.
« Ответ #8 : 24/07/2014 15:27:55 »
volatile unsigned char i = 0; data_e; temp = 0; гыыы. во я слепошарый не заметил. вопрос: а чо студия ничо не сказала что тут каким то переменным неизвестного типа производится присвоение ?...
« Ответ #9 : 24/07/2014 15:30:09 »
а окно бьюилда внизу, и маленькое. Я и не замечал - он показывал, что скомпилировал, типа все ОК, а варнинги я уже потом увидал.
« Ответ #10 : 24/07/2014 21:33:58 »
Народ, поправьте, если не прав - аппаратные прерывания в АВР не бывают вложенными???
Т.е., если я в обработке INT1 запрещаю прерывание от компаратора, то оно не сработает?, при этом даже не надо флаг I (общий запрет прерываний ) сбрасывать?
Я в обработке сделал запрет прерывания от АС, и до кучи, как в ДШ прописано на atmega8 еще установил!!! флаг прерывания ACI  - там написано, что надо "1" записать в него для его сброса. Я в прострации.
« Последнее редактирование: 24/07/2014 21:44:45 от Two_byte »
« Ответ #11 : 25/07/2014 00:34:55 »
На temp=0 должен был быть еггог, если авр-студия не начала поддерживать С++11;
Насчёт вложенныз запретов прерываний - нигде не видел. даже на х86 что бы какое-либо прерывание разрешить внутри другого прерывания, приходилось PIC(контроллёр прерываний) напрямую программировать. cli - лочит всё подряд.
З.Ы. Ну а насчёт точек, запятых и точек с запятой - тут СИ очень привередлив. Я тоже несколько раз смотрел код и нифига не увидел :(
Оффлайн Юр
  • Похвалили: 103 раз(а)
« Ответ #12 : 25/07/2014 00:49:36 »
Вложенное прерывание сработает в зависимости от приоритета, а cli разрешит и вне зависимости от приоритета. Это общая идеология во всех линейках микроконтроллеров и 86-е системы конечно то же самое.
А точки с запятой - это типичная беда когда внезапно меняешь всякие васики на си и обратно. :)
Есть только  миг
« Ответ #13 : 25/07/2014 00:50:42 »
Я тоже сначала не заметил, но, temp, это так, до кучи - нигде она не используется. WinAVR инициализирует переменные в самом начале. В ИДА полез просто поглянуть на код, а, там такое!!!
На Х86 реально можно вызвать прерывание из обработчика другого, но, только программным путем.
А, насчет точек и иже с ними - только седня прокрутил окно бьюилдера, и там такое!!!. Ну тут и начал думать. Код естессно не полный - выложен алгоритм для сектора в 42.35 градуса. INT0 - это прерывание по началу сектора, INT1 - по концу сектора,  ANACOMP - прерывание по искре. Отношение сектора к углу окружности = 8.5 ровно.
Т.е. надо построить график зависимости УЗО от оборотов двигателя. Математику естессно разгрузил, подсчитав константы. Осталось только добавить запись в Епром, и звуковую сигналку. А так, всем спасибо!!!. Volatile прочитал вчера - ничего не нарушил, все по канонам написанного. ( по моим скудным понятиям ).
« Ответ #14 : 25/07/2014 00:52:46 »
То ЮР -> насколько я знаю, в отличие от 51-го микрокомплекта, у АВР нет приоритета прерываний.
« Ответ #15 : 25/07/2014 01:01:59 »
Там иерархия прерываний. Поэтому если сработал, допустим int 3 для того, что бы разрешить внутри обработчика int3 клаву (int 9) надо с PICом общаться. sti/cli работают по всем int`ам (исключение виртуальные режимы, например virt 86 внутри protected 386)
Я давно уже ничего серъёзного не писал, мог и накосячить. Но признаки были, будто i неинициализирована... Ну а точки и запятые - это да, бич СИ, так же как и скобки (если вложенность больше пяти одну забытую скобку в гигантской функции откапать сложно - ругань компилера начинается парой-тройкой экранов ниже)
« Ответ #16 : 25/07/2014 01:06:27 »
Я в общем то про то же и говорил, но!!!, из допустим INT3, можно вызвать INT9 программным путем, разрешив перепрограммирование контроллера прерываний. Это я про DOS. sti, cli не берем - это глобально.
Меня больше АВР волнует - у меня прерывание по искре может быть после INT1, а, вот это задница. Правда сегодня код малька подправил. Если интересует, могу завтра кинуть.
« Ответ #17 : 25/07/2014 01:12:53 »
Я не про это. Програмно я могу вызвать что угодно и когда угодно. Допустим int3 - (дебаг поинт - плохой пример), пусть будет деление на 0 = int0. Лочит всё что ниже по приоритету. Допустим я пишу свой супер-пупер обработчик этого int`a, так вот для того, чтобы принять ввод с клавы внутри "деления на 0" мне нужно через PIC контроллер разрешить int 9 (при этом остальные могут висеть залоченные), а могу просто подать PICу команду, мол я отработал и он разрешить все прерывания. При этом cli не прокатит нужно вот это:
mov     al,20H             ;послать сигнал "конец прерывания"
out     20H,al             ; контроллеру прерываний 8259
« Ответ #18 : 25/07/2014 01:16:39 »
Вах, Федя, давно с х86 не работал, мог и забыть что-то. Но ты мне лучше по АВР скажи, если юзал. Я просто в ДШ не увидел иерархии прерываний. Поэтому лучше завтра исходник кину, там и поглядим, где я не прав.
Самое главное алгоритм правильно вписать, остальное ерунда. Мне кстати VVM сказал, что, если в программе нет деления на ноль, то это моветон.
Оффлайн Юр
« Ответ #19 : 25/07/2014 01:28:10 »
Да, точно, в авр есть приоритеты, но это относится к их одновременному аппаратному вызову - первым выполняется то, которое имеет меньший адрес. Ты прав. А запрета на вложения по умолчанию никакого нет.
Есть только  миг
« Ответ #20 : 25/07/2014 01:29:06 »
Со встройкой я вообще дела не имел, только x86 и пытался изучать x86_64, но без практики - это ниочём. Закончу балкон - займусь эклз-либ... Хоть какая-то да практика :(
VVM
Это да. Деление на ноль и runtime error 200 просто обязательно должны выскакивать раз в месяц, в хорошо написанной программе, иначе это просто быдлокод :D
« Ответ #21 : 25/07/2014 01:36:18 »
Так, подводим итоги - в АВР есть иерархия прерываний ( не видел в ДШ, кто первым пришел, того и тапки ), прерывания не могут вызываться ( в АВР ) из другого прерывания, поскольку флаг I сбрасывается при входе в обработчик прерывания, восстанавливается командой reti,  прерывание ( другое ) может быть сброшено из п\п обработки прерывания???
« Ответ #22 : 25/07/2014 01:42:41 »
Вот так вот, юзаешь Си для АВР, а, тут бац, и вторая смена! (с).
Оффлайн Юр
« Ответ #23 : 25/07/2014 01:49:58 »
Про что это?
The list also determines the priority levels of the different interrupts. The lower the address the higher is the priority level
Для чего же тогда система приоритетов, если все равно при входе в процедуру прерывания другие прерывания автоматически становятся запрещены сбросом этого флага даже для прерываний с более высоким приоритетом?
Есть только  миг
« Ответ #24 : 25/07/2014 02:05:33 »
...Для чего же тогда система приоритетов, если все равно при входе в процедуру прерывания другие прерывания автоматически становятся запрещены сбросом этого флага даже для прерываний с более высоким приоритетом?
Наверняка для разруливания одновременного прихода двух и более прерываний...
« Ответ #25 : 25/07/2014 02:08:53 »
The lower the address the higher is the priority level - Меньший адрес, имеет бОльший приоритет. ОК, только при входе в прерывание флаг I сбрасывается, и вложенных прерываний быть не может. Соот-стно, если я обнулю флаг какого-то прерывания в обработке другого прерывания, то его ( обнуленного ), не будет???
Мож вопросы и ламерские, но надо до конца разобраться. На МК51 у меня таких вопросов не возникает. (Паять схему с двумя светодиодами не предлагать. ) - времени нету.
И в Си я не гуру. В АСМ-е, пожалуйста.
« Ответ #26 : 25/07/2014 02:43:16 »
...Соот-стно, если я обнулю флаг какого-то прерывания в обработке другого прерывания, то его ( обнуленного ), не будет???
Приходят несколько сигналов на входы - срабатывает такт процессора -> проц смотрит сигналы по интам и выбирает с наивысшим (меньший адрес/номер) приоритетом. Запрещаются ВСЕ прерывания и вызывается обработчик. Как я понял в АВРе разрешить прерывания из обработчика можно только выполнив iret... Затем проц снова смотрит прерывания и т.д.
По теории может возникнуть ситуация "пропуска" прерывания с меньшим приоритетом, если более высокое слишком долго "думает" (тут "пропуски" уже по аналогии с х86)...
