Автор Тема: Скрипт смены зав.№  (Прочитано 2069 раз)
Оффлайн patriot
  • Патриот, patriot
Скрипт смены зав.№
« : 09/07/2021 15:08:30 »
Атол дал такой (копия из чата)
cmd = new
Uint8Array([0x2b,0x83,0x01,0x3b,0x30,0x30,0x31,0x30,0x36,0x32,0x30,0x30,0x36,0x36,0x35,0x32,0x36,0x38,0x3b,0x30,0x30,0x31,0x30,0x36,0x32,0x30,0x30,0x30,0x32,0x39,0x33,0x38,0x35,0x3b,0x3b,0x27,0x47,0x46,0xa1,0xdd,0x08,0xdd,0xbb,0xcc,0xc0,0x63,0xd5,0x40,0xbd,0x44,0x36,0x20,0x44,0x6c,0x43,0x97,0x28,0x08,0xf4,0x3c,0x2b,0xc0,0x3f,0xb3,0x74,0x2e,0x3e,0xaa,0x9e,0xb1,0x2e,0xf1,0xc5,0x39,0x34,0x55,0x30,0x73,0xac,0xe3,0xaf,0xe3,0xa3,0xce,0x7b,0x3c,0x12,0xb0,0x87,0xbc,0xe8,0xf0,0x7a,0x4b,0xa6,0x44,0x4c,0x13,0x23]);
Fptr.setParam(Fptr.LIBFPTR_PARAM_COMMAND_SUBSYSTEM, 197);
Fptr.setParam(Fptr.LIBFPTR_PARAM_COMMAND_BUFFER, cmd);
Fptr.setParam(Fptr.LIBFPTR_PARAM_TIMEOUT_ENQ, 20000);
Fptr.runCommand();
for (k = 1; k < 10000000; k++) { };
do { for (k = 1; k < 3000000; k++) { }
Fptr.setParam(Fptr.LIBFPTR_PARAM_DATA_TYPE, Fptr.LIBFPTR_DT_STATUS); } while
(0 != Fptr.queryData());
licStr = "{\"devices\": [{\"serialNumber\": \"00106200029385\", \"model\":
\"062\", \"licenses\": [{\"parameters\": {\"id\": 11103523, \"platform\":
\"1\", \"type\": \"5\", \"description\": \"\", \"subject\": {\"matter\":
\"temporal\", \"quantity\": 36500}, \"category\": \"production\",
\"activation\": {\"mode\": \"time\", \"date\": \"2020-01-01T00:00:00\"}},
\"data\":
\"0245ba7a52cd4c3fcf76d5e8030d59085609275d8f329c3644138bad3869bfc507a75a7589b5bcbc035f803f0e640b76f23805a13be5e58fc6858b1929fe5eb07c1b1683abe6d248844f48dd4035e33d2706a34e036a09736cca94fd4dbd1afdeb\"},
{\"parameters\": {\"id\": 11103522, \"platform\": \"1\", \"type\": \"4\",
\"description\": \"\", \"subject\": {\"matter\": \"temporal\", \"quantity\":
36500}, \"category\": \"production\", \"activation\": {\"mode\": \"time\",
\"date\": \"2020-01-01T00:00:00\"}}, \"data\":
\"023afa907a1dc886ef137223b02fe4efa595c8a62570e315154082930099cb9c7285676eb0f6be8c92976ac11599737cc95899ee9b705d3263b21df11ee57f30f19aa5d3bfe792f1ff273e15940aef05b16b288dc54510e6fd10708af531a44413\"},
{\"parameters\": {\"id\": 11103521, \"platform\": \"1\", \"type\": \"3\",
\"024d13d6b7fd4cb74571bdeab291dcb75947473fdb06e17b2a4bb78b6150300f919f71e9d14cb15cd8528bc15f54b861df636d3ee2157747a914302bdd2de71561bd60730fdc9e5c526347e01ffd71e5a1788cb5e6764862853b005527dd5ed30b\"},
{\"parameters\": {\"id\": 11103519, \"platform\": \"1\", \"type\": \"1\",
\"02d07657055a8104b9db6de9776a46f20bd93b7f141c064fcdb96d22540383c07a186bca3fe0b212694a15ddf11f5148140effadd14568309c57afba8cd28b2b512f10199bcde9abe48096caac6d83c8bcc21fadcbd2799fb6c771d90efd3937ba\"},
{\"parameters\": {\"id\": 9842173, \"platform\": \"1\", \"type\": \"2\",
28855}, \"category\": \"commercial\", \"activation\": {\"mode\": \"time\",
\"022824c6662c55586f634e91c762832d32fa31d1c16d2860d12abd4b9433bf7ff0a4bb9b2e0ae2090b4194aaa890404da5c17386ae387f6d29a8b0bb4cd3129e444c9e848d612b8851630de3ded87aa9bd233898cee5d74a22a9aa5e312e74c548\"}],
\"uin\": \"00106200665268\", \"key\": {\"private\":
\"cb948bca3b4247a418469f3259c3d885b7e4646f0ba76f425729e74cd946ce97\",
\"public\":
\"023d5b514e6ef34a42a1e29579a13ba75b97a1d104703802b1a07cb5f5cf2536ca\",
\"signature\":
\"5f48c372ff2ef399cce00bd0d505412eed08f33f65e4d10c35acf45d002dd19517b23446e53e0615acdbafa600d6ccee7fd4ae9d2b66d671250b2870e61f9eec\"},
\"macs\": {\"count\": 1, \"MACAddresses\": [{\"address\":
\"E4-F3-27-0F-A0-2A\", \"default\": true}]}}], \"idRequest\":
\"545c932850a8428692e8a57eacb8a3e8\"}";
Fptr.setParam(Fptr.LIBFPTR_PARAM_LICENSE_NUMBER, 1);
Fptr.setParam(Fptr.LIBFPTR_PARAM_LICENSE, licStr);
Fptr.writeLicense();
Fptr.setParam(Fptr.LIBFPTR_PARAM_REPORT_TYPE, Fptr.LIBFPTR_RT_KKT_INFO);
Fptr.report();
А он не работает
Ошибка выполнения скрипта
unterminated string(line11)
"Уберите лишние энтеры
Каждая команда заканчивается точкой с запятой"
Где они тут?
Оффлайн patriot
  • Патриот, patriot
Re: Скрипт смены зав.№
« Ответ #1 : 09/07/2021 15:10:56 »
Техпод атола просто бесит
"Лог драйвера"
"Необходимо убрать лишние энтеры, как и говорилось ранее
которые возникли при копипасте скрипта"
« Ответ #2 : 11/07/2021 03:16:11 »
Я не догоняю?, сложно вставить в скрипт по исполнению строку типа "if val"[i"] = 13h, then тралалалала...???. Или великие программеры таким не заморачиваются ( ну типа ниже их достоинства )?.
